ACL Management
< All Topics
Print
ACL Management
ACL refers to the Access Control List. Cyberpanel allows you to provide a way to create accounts with different levels of access. You can give.
For example if a user is created with admin ACL then that is a super user and has access to all the features in CyberPanel.
1-Create New ACL
2-Delete ACL (You can delete custom ACL not the Default)
3-Modify ACL (You can modify Custom created ACL)
Create ACL account:
Cyberpanel allows you to create an ACL account based on your custom access requirements.
As you know Cyberpanel offers three types of accounts for the management services
  1. Admin
  2. Reseller
  3. User
At every level, access is different and you can not modify it with that ACL. These accounts come with default access.
Set the name first and select the from the list of features to provide the control. And save.
Acl will be created and will be list under ACL when you Create New User.
Create New User with ACL:
Now after the creation of ACL it will be listed under ACL list When you create a user account. And you can choose for that account.
This will ease you to create multiple accounts with that access.
The user will granted with the access of the features that is setted in the ACL (eg staff) here.
Table of Contents
