< All Topics
Print
Add Destination: Scheduled Local/SFTP Remote Backups
Posted
Updated
Byadmin
CyberPanel allows you to schedule and send backups to remote locations (local/sftp) (Daily/Weekly).
Note: if you are using storage boxes from providers like Hetzner, you need to enable SSH support, otherwise SFTP backups will not work.
Add/Delete Destination
SFTP Destination
Backups -> Add/Delete Destination
- Name: This can be anything you can remember.
- IP Address: This can either be IP address or hostname of the remote SFTP server.
- Username: username of your sftp server
- Password: password of your sftp server
- Port: default ssh port is 22, if it is anything else do specify
- Path: thats the custom path where CyberPanel will store backups
Local Backups
Backup > Add/Delete Destination
- Path: If you are selecting local backups, CyberPanel will store backups in this path.
Once the destination is added, you can schedule either daily or weekly backups to this destination.
Posted
Updated
Byadmin
