Create IP Pool
< All Topics
Print
Create IP Pool
After installation and successfully configuration of network bridge. You need to create your first IP Pool, so that you can start creating virtual machines.
What are IP Pools?
IP Pools in CyberPanel are collection of IP Addresses with same Gateway and Netmask address.
How to create IP Pool?
To create IP Pool, navigate to https://<IP Address>:8090/ip/createIPPool
Fill in all the required details to create IP Pool, if you only have 1 IP Address, you can enter same IP Address in Starting IP and Ending IP. We will see how to add/delete IPs or assign MAC Addresses to these IPs later.
Table of Contents
