CyberPanel Custom OpenLiteSpeed – Installation & Product Guide
What is CyberPanel Custom OpenLiteSpeed?
CyberPanel maintains a custom-built OpenLiteSpeed binary that includes enhancements not available in the stock version from LiteSpeed Technologies. This custom binary is free and installed automatically with CyberPanel.
Important: The custom OpenLiteSpeed binary is a separate product from the .htaccess Module. Understanding the difference between these products is essential before purchasing.
Three Products — Know the Difference
CyberPanel offers three distinct OpenLiteSpeed-related products:
| Custom OLS Binary | .htaccess Module | OLS for Any Panel | |
| What it is | Modified OpenLiteSpeed server binary with patches | Add-on module (cyberpanel_ols.so) that processes Apache .htaccess files |
Complete Apache-to-OLS replacement package for Plesk/cPanel (includes custom binary + Apache config auto-parser) |
| Price | Free (included with CyberPanel) | $59/year or $199 lifetime | Free (open source, GPLv3) |
| Target | CyberPanel users | Any OLS user on any panel | Plesk & cPanel users replacing Apache |
| PHPConfig LSIAPI hooks | Yes | — | Yes (same custom binary) |
| Origin header forwarding | Yes | — | Yes |
| Static linking | Yes | — | Yes |
| ModSecurity ABI compat | Yes | — | Yes |
| ReadApacheConf (auto-parses existing Apache configs) | No | No | Yes — reads Apache vhosts and creates OLS configs automatically |
| Apache .htaccess processing | No | Yes — headers, redirects, access control, PHP directives, error docs, expires, FilesMatch, SetEnv | No (purchase .htaccess Module separately) |
| WordPress brute force protection | No | Yes | No (included with .htaccess Module) |
| License required | No | Yes (key-based) | No |
In plain terms:
- Custom OLS Binary = The server engine itself, with patches for PHPConfig, CORS/Origin support, static linking, and ModSecurity compatibility. Installed automatically with CyberPanel. Free.
- .htaccess Module = A paid add-on that teaches OpenLiteSpeed how to read Apache
.htaccessfiles — including headers, redirects, PHP values (php_value/php_flag), access control, brute force protection, and more. Works on any panel (CyberPanel, Plesk, cPanel, standalone). $59/year or $199 lifetime. See installation & activation guide. - OLS for Any Panel = A free installer for Plesk and cPanel users. It installs our custom OLS binary and adds ReadApacheConf — a tool that automatically reads your existing Apache configurations and creates matching OLS virtual hosts. All your sites work immediately without manual migration. The .htaccess module can be purchased separately for full .htaccess support. Register free.
Custom OLS Binary — What’s Inside
1. PHPConfig Support
Five patches are applied to the OLS source code to add LSIAPI hooks for PHP configuration handling. When paired with the .htaccess Module, this enables php_value and php_flag directives in .htaccess files.
2. Origin Header Forwarding
Properly forwards the Origin header in reverse proxy setups. Fixes “Connection Lost” errors in modern applications like n8n (v1.87.0+) that validate the Origin header.
3. Static Linking
Statically linked against libstdc++ and libgcc, eliminating GLIBC version dependency issues. One binary works across Ubuntu 20.04–24.04 and RHEL/AlmaLinux 8.x–9.x.
4. ModSecurity ABI Compatibility
A matching ModSecurity module is built against the same OLS headers. Never mix stock and custom binaries — custom OLS requires the custom ModSecurity module to avoid segfaults and 503 errors.
Supported Operating Systems
| OS | Version | Binary | Status |
| Ubuntu | 20.04, 22.04, 24.04 | ubuntu-static |
Fully Supported |
| Debian | 12+ | ubuntu-static |
Fully Supported |
| AlmaLinux / Rocky Linux | 8.x | rhel8-static |
Fully Supported |
| AlmaLinux / Rocky Linux | 9.x | rhel9-static |
Fully Supported |
| RHEL | 8.x, 9.x | rhel8-static / rhel9-static |
Fully Supported |
| CloudLinux | 8.x | rhel8-static |
Fully Supported |
Supported Control Panels
| Panel | Custom OLS Binary | .htaccess Module ($59/yr) | OLS for Any Panel (Free) |
| CyberPanel | Auto-installed on upgrade | Available (paid) | N/A |
| Plesk | Included via OLS for Any Panel | Available (paid) | Full support |
| cPanel / WHM | Included via OLS for Any Panel | Available (paid) | Full support |
| Standalone (no panel) | Manual install | Available (paid) | N/A |
Installation
CyberPanel Users (Automatic)
The custom OLS binary is installed automatically during CyberPanel upgrades:
CyberPanel auto-detects your OS, downloads the correct binary, verifies SHA256 checksums, and installs it.
Plesk & cPanel Users (OLS for Any Panel — Free)
- Register at platform.cyberpersons.com/cyberpanel/openlitespeed/
- Receive install/uninstall commands via email
- Run one command on your server — Apache is replaced with zero downtime
- All existing sites work immediately (ReadApacheConf auto-parses Apache configs)
One command to install, one command to revert to Apache. No license keys. Optionally purchase the .htaccess Module for full .htaccess support. After installation, install the cPanel/WHM Management Plugin for a graphical interface to manage OLS, PHP, and cache.
Manual Installation (Advanced)
For standalone servers or custom setups, three files are installed:
| File | Purpose | Destination |
openlitespeed-phpconfig-x86_64-*-static |
Custom OLS binary | /usr/local/lsws/bin/openlitespeed |
cyberpanel_ols_x86_64_*.so |
.htaccess module (requires license) | /usr/local/lsws/modules/cyberpanel_ols.so |
mod_security-compatible-*.so |
ModSecurity module | /usr/local/lsws/modules/mod_security.so |
Ubuntu / Debian
cd /tmp wget -q https://cyberpanel.net/openlitespeed-phpconfig-x86_64-ubuntu-static wget -q https://cyberpanel.net/cyberpanel_ols_x86_64_ubuntu.so wget -q https://cyberpanel.net/mod_security-compatible-ubuntu.so wget -q https://cyberpanel.net/SHA256SUMS_UBUNTU sha256sum -c SHA256SUMS_UBUNTU --ignore-missing /usr/local/lsws/bin/lswsctrl stop cp /usr/local/lsws/bin/openlitespeed /usr/local/lsws/bin/openlitespeed.backup.$(date +%s) cp openlitespeed-phpconfig-x86_64-ubuntu-static /usr/local/lsws/bin/openlitespeed cp cyberpanel_ols_x86_64_ubuntu.so /usr/local/lsws/modules/cyberpanel_ols.so cp mod_security-compatible-ubuntu.so /usr/local/lsws/modules/mod_security.so chmod 755 /usr/local/lsws/bin/openlitespeed /usr/local/lsws/modules/*.so /usr/local/lsws/bin/lswsctrl start
RHEL 9 / AlmaLinux 9 / Rocky Linux 9
cd /tmp wget -q https://cyberpanel.net/openlitespeed-phpconfig-x86_64-rhel9-static wget -q https://cyberpanel.net/cyberpanel_ols_x86_64_rhel.so wget -q https://cyberpanel.net/mod_security-compatible-rhel.so wget -q https://cyberpanel.net/SHA256SUMS_RHEL9 sha256sum -c SHA256SUMS_RHEL9 --ignore-missing /usr/local/lsws/bin/lswsctrl stop cp /usr/local/lsws/bin/openlitespeed /usr/local/lsws/bin/openlitespeed.backup.$(date +%s) cp openlitespeed-phpconfig-x86_64-rhel9-static /usr/local/lsws/bin/openlitespeed cp cyberpanel_ols_x86_64_rhel.so /usr/local/lsws/modules/cyberpanel_ols.so cp mod_security-compatible-rhel.so /usr/local/lsws/modules/mod_security.so chmod 755 /usr/local/lsws/bin/openlitespeed /usr/local/lsws/modules/*.so /usr/local/lsws/bin/lswsctrl start
RHEL 8 / AlmaLinux 8 / Rocky Linux 8
cd /tmp wget -q https://cyberpanel.net/openlitespeed-phpconfig-x86_64-rhel8-static wget -q https://cyberpanel.net/cyberpanel_ols_x86_64_rhel8.so wget -q https://cyberpanel.net/mod_security-compatible-rhel8.so wget -q https://cyberpanel.net/SHA256SUMS_RHEL8 sha256sum -c SHA256SUMS_RHEL8 --ignore-missing /usr/local/lsws/bin/lswsctrl stop cp /usr/local/lsws/bin/openlitespeed /usr/local/lsws/bin/openlitespeed.backup.$(date +%s) cp openlitespeed-phpconfig-x86_64-rhel8-static /usr/local/lsws/bin/openlitespeed cp cyberpanel_ols_x86_64_rhel8.so /usr/local/lsws/modules/cyberpanel_ols.so cp mod_security-compatible-rhel8.so /usr/local/lsws/modules/mod_security.so chmod 755 /usr/local/lsws/bin/openlitespeed /usr/local/lsws/modules/*.so /usr/local/lsws/bin/lswsctrl start
Verification
# Check OLS is running /usr/local/lsws/bin/openlitespeed -v # Verify static linking (should return empty) ldd /usr/local/lsws/bin/openlitespeed | grep -E "libstdc++|libgcc" # Check service status systemctl status lshttpd
Upgrading from Stock OpenLiteSpeed
- Take a snapshot/backup of your server
- Stop OLS:
/usr/local/lsws/bin/lswsctrl stop - Backup:
cp /usr/local/lsws/bin/openlitespeed /usr/local/lsws/bin/openlitespeed.backup - Install custom binary and modules (see Manual Installation above)
- Start OLS:
Existing vhost configs, SSL certificates, and PHP settings are preserved.
Troubleshooting
GLIBC version errors
./litespeed: /lib/x86_64-linux-gnu/libc.so.6: version 'GLIBC_2.33' not found
You’re using a dynamically linked binary. Download the correct static-linked binary for your OS.
ModSecurity causes 503 errors or segfaults
ABI mismatch. Install the matching mod_security-compatible-*.so from cyberpanel.net.
N8N “Connection Lost” errors
Missing Origin header forwarding. Upgrade to the custom OLS binary.
OLS fails to start
cat /usr/local/lsws/logs/error.log /usr/local/lsws/bin/openlitespeed -t systemctl restart lsws
Getting Help
- Support: [email protected]
- Knowledge Base: cyberpanel.net/KnowledgeBase
- Forums: forums.cyberpanel.net
- Purchase .htaccess Module: $59/year or $199 lifetime
- .htaccess Module Installation Guide: Installing & Activating the .htaccess Module
- cPanel/WHM Plugin Guide: Managing OpenLiteSpeed on cPanel
- Register OLS for Any Panel (free): platform.cyberpersons.com
