Reseller Management
Cyberpanel offers three types of accounts for the management services.
- Admin
- Reseller
- User
In this phase we will get to know about the reseller account.
If you would like to acquire fundamental knowledge about users in CyberPanel, please refer to the ‘Managing Users’ guide. While the functioning of resellers is already explained in that section, we will provide a dedicated tutorial specifically focusing on reseller functionality.
Step 1: Create New User.
First access and open the cyberpanel dashboard. Go to
- User
- Create New User
During the creation of account add the required details and on the ACL list choose “Reseller”
You can also set the limit of the site than a reseller can create.
There are 3 types of control lists already created in CyberPanel (admin, reseller, and user) you can also create custom control lists as well, which is not the topic of this tutorial. This post discusses reseller ACL only.
Step 2: Login to reseller.
After creation on the user account as reseller. You will be able to access the reseller account with the reseller credentials. Resellers can create a user and also can set the limit for the user.
Resellers have limited access than that of Admin.
- Website limit.
Users with reseller ACL have the ability to create websites, so admin can restrict as to how many websites they can create. Please remember this limit is not for child-domains that you can create under websites. Limits of child-domains can be controlled via Packages.
Now if there are 3 users under this reseller (reseller can also create users) and if they have 10 sites each then reseller itself can create 70 sites which then becomes a total of 100 websites. - Reseller users
With a reseller account you will be able to create multiple users.
Resellers can edit, modify and restrict users. User account will only be able to manage sites. User account under reseller will not be able to create sites.
