Resource Limits Guide for CyberPanel
< All Topics
Print
Overview
CyberPanel now supports comprehensive resource limits for shared hosting environments using OpenLiteSpeed’s native cgroups v2 integration. This feature allows you to enforce CPU, memory, I/O, inode, process, and connection limits on a per-package basis.
Features
  • Memory Limits: Set RAM limits (in MB) for each hosting package
  • CPU Limits: Allocate specific CPU cores to packages
  • I/O Limits: Control disk I/O bandwidth (in MB/s)
  • Inode Limits: Limit the number of files/directories
  • Process Limits: Set soft and hard process count limits
  • Connection Limits: Control maximum concurrent PHP connections
Prerequisites
System Requirements
  1. Linux Kernel: 5.2+ (for native cgroups v2 support)
    • Ubuntu 20.04+, Debian 11+, CentOS Stream 9+, AlmaLinux 9+, Rocky Linux 9+
    • RHEL 8 family (RHEL 8, AlmaLinux 8, Rocky 8, CloudLinux 8) with cgroups v2 manually enabled
  2. CyberPanel Version: v2.4.4-dev or later
  3. OpenLiteSpeed: Installed and running
Checking Kernel Support
To verify your system supports cgroups v2:
# Check if cgroups v2 is available
ls /sys/fs/cgroup/cgroup.controllers
# Check kernel version
uname -r
Enabling cgroups v2 on RHEL 8 Family
If you’re running RHEL 8, AlmaLinux 8, Rocky 8, or CloudLinux 8:
# Edit GRUB configuration
vi /etc/default/grub
# Add to GRUB_CMDLINE_LINUX:
systemd.unified_cgroup_hierarchy=1 cgroup_no_v1=all
# Update GRUB
grub2-mkconfig -o /boot/grub2/grub.cfg
# Reboot
reboot
# Verify after reboot
mount | grep cgroup2
Using Resource Limits
Step 1: Create a Package with Resource Limits
  1. Navigate to Packages
    • Go to Packages → Create Package
  2. Basic Package Information
    • Enter Package Name
    • Set Disk Space (MB)
    • Set Bandwidth (MB)
    • Configure Email Accounts, Databases, FTP Accounts, Allowed Domains
  3. Enable Resource Limits
    • Check the “Enforce Disk Limits” checkbox
    • This enables all resource limit enforcement (not just disk)
  4. Configure Advanced Resource LimitsUnder “Advanced Resource Limits” section:CPU & Memory:
    • Memory Limit (MB): RAM limit (default: 1024 MB)
    • CPU Cores: Number of CPU cores (default: 1)
    I/O & Storage:
    • I/O Limit (MB/s): Disk I/O bandwidth (default: 10 MB/s)
    • Inode Limit: Maximum files/directories (default: 400000)
    Process & Connection Limits:
    • Max Connections: Concurrent PHP connections (default: 10)
    • Process Soft Limit: Soft process count (default: 400)
    • Process Hard Limit: Hard process count (default: 500)
  5. Save Package
Step 2: Create a Website with Resource Limits
  1. Navigate to Websites
    • Go to Websites → Create Website
  2. Website Configuration
    • Enter Domain Name
    • Select the package you created (with resource limits)
    • Choose PHP version
    • Configure other settings as needed
  3. Create Website
    • Click “Create Website”
    • CyberPanel will automatically:
      • Detect and configure OpenLiteSpeed cgroups (if needed)
      • Apply resource limits to the website’s user
      • Set filesystem quotas
Step 3: Verify Resource Limits
After creating a website, you can verify the limits are applied.
Check cgroups Configuration
# Check if OpenLiteSpeed cgroups are enabled
grep -A 5 "CGIRLimit" /usr/local/lsws/conf/httpd_config.conf
# Should show: cgroups 1
Check User Resource Limits
# List limits for a specific user
/usr/local/lsws/lsns/bin/lscgctl list-user <username>
# Example output:
#     "1005": {
#         "name": "example1234",
#         "cpu": "200",      # 200% = 2 cores
#         "io": "20M",       # 20 MB/s
#         "mem": "2.0G",     # 2GB RAM
#         "tasks": "800"     # Max 800 processes
Check Filesystem Quotas
# Check inode limit for user
quota -u <username>
# Example output:
# Disk quotas for user example1234 (uid 1005):
#      Filesystem  blocks   quota   limit   grace   files   quota   limit   grace
#       /dev/sda1     104       0       0              26  500000  500000
#                                                          Inode limits
Check Kernel-Level cgroups
# Find the user ID
id -u <username>
# Check memory limit (in bytes)
cat /sys/fs/cgroup/user.slice/user-<UID>.slice/memory.max
# 2147483648 = 2GB
# Check process limit
cat /sys/fs/cgroup/user.slice/user-<UID>.slice/pids.max
# 800
Testing Resource Limits
Testing Memory Limits
Create a PHP script to test memory limits:
<?php
// test-memory.php
ini_set('memory_limit', '-1'); // Remove PHP limit to test cgroup limit
ini_set('max_execution_time', '60');
echo "Testing memory limit...\n";
$data = [];
// Try to allocate more than the package limit
for ($i = 0; $i < 2000; $i++) { // Try 2GB
    $data[] = str_repeat('X', 1024 * 1024); // 1MB chunks
    if ($i % 100 == 0) {
        echo "Allocated: " . $i . " MB\n";
        flush();
echo "Completed!\n";
Access via web browser: http://yourdomain.com/test-memory.php
Expected behavior: Process should be terminated when exceeding the memory limit.
Testing Process Limits
Create a PHP script to spawn processes:
<?php
// test-processes.php
echo "Testing process limits...\n";
$processes = [];
$max = 1000; // Try to exceed limit
for ($i = 0; $i < $max; $i++) {
    $pid = pcntl_fork();
    if ($pid == -1) {
        echo "Failed to fork at process $i\n";
        break;
    } elseif ($pid) {
        $processes[] = $pid;
        echo "Created process $i (PID: $pid)\n";
        flush();
    } else {
        sleep(30);
        exit(0);
echo "Created " . count($processes) . " processes\n";
// Clean up
foreach ($processes as $pid) {
    pcntl_waitpid($pid, $status);
Expected behavior: Fork should fail when reaching the process hard limit.
Automatic Setup
CyberPanel automatically handles OpenLiteSpeed cgroups setup:
  1. First-time Setup: When you create a website with resource limits enabled:
    • Checks if cgroups v2 is available
    • Runs lssetup if LiteSpeed Containers not configured
    • Enables cgroups in OpenLiteSpeed config
    • Restarts OpenLiteSpeed
    • Applies resource limits
  2. Subsequent Websites: Resource limits are applied instantly without restarting.
Important Notes
Resource Sharing
  • Subdomains and Addon Domains: Share the same limits as the main domain
    • All domains under the same website use the same Linux user
    • Limits are enforced per-user, not per-domain
I/O Limits Caveat
On some systems, the I/O controller may not be delegated to user slices by systemd. In this case:
  • lscgctl will store the I/O configuration
  • But kernel-level enforcement may not work
  • CPU, Memory, and Process limits work on all supported systems
Memory Limit Enforcement
Memory limits are enforced at the cgroup level:
  • When limit is reached, processes are killed by the kernel
  • Check /sys/fs/cgroup/user.slice/user-<UID>.slice/memory.events for OOM events
Connection Limits
The “Max Connections” setting controls:
  • Maximum concurrent PHP-FPM/LSPHP processes
  • Configured in OpenLiteSpeed virtual host extprocessor settings
Troubleshooting
Resource Limits Not Working
  1. Check if enforcement is enabled:mysql -u root -e “SELECT packageName, enforceDiskLimits FROM cyberpanel.packages_package;”Ensure enforceDiskLimits is 1 for your package.
  2. Check cgroups are enabled:grep “cgroups” /usr/local/lsws/conf/httpd_config.confShould show cgroups 1.
  3. Check lscgctl is configured:/usr/local/lsws/lsns/bin/lscgctl list-all
  4. Check CyberPanel logs:tail -100 /usr/local/CyberCP/logs/access.log
RHEL 8 Family: cgroups v2 Not Available
If you see errors about cgroups v2 not being available on RHEL 8/AlmaLinux 8/Rocky 8:
  1. Follow the Enabling cgroups v2 on RHEL 8 Family steps
  2. Reboot the server
  3. Verify with mount | grep cgroup2
LiteSpeed Containers Not Configured
If you see “You must configure LiteSpeed for LiteSpeed Containers”:
  1. CyberPanel should auto-run lssetup
  2. If it doesn’t work, manually run:/usr/local/lsws/lsns/bin/lssetup -c 2 -n 0 -s /usr/local/lsws
  3. Restart OpenLiteSpeed:/usr/local/lsws/bin/lswsctrl restart
Package Recommendations
Here are some example package configurations for different use cases:
Basic Shared Hosting
  • Memory: 512 MB
  • CPU: 1 core
  • I/O: 5 MB/s
  • Inodes: 200,000
  • Max Connections: 5
  • Proc Soft/Hard: 200/300
Standard Shared Hosting
  • Memory: 1024 MB (1 GB)
  • CPU: 1 core
  • I/O: 10 MB/s
  • Inodes: 400,000
  • Max Connections: 10
  • Proc Soft/Hard: 400/500
Premium Shared Hosting
  • Memory: 2048 MB (2 GB)
  • CPU: 2 cores
  • I/O: 20 MB/s
  • Inodes: 800,000
  • Max Connections: 20
  • Proc Soft/Hard: 600/800
Business Hosting
  • Memory: 4096 MB (4 GB)
  • CPU: 4 cores
  • I/O: 50 MB/s
  • Inodes: 1,000,000
  • Max Connections: 50
  • Proc Soft/Hard: 1000/1500
FAQ
Q: Do I need to restart OpenLiteSpeed after changing package limits? A: No, limits are applied immediately when you create a website or modify a package (though the website needs to be recreated for new limits to apply).
Q: Can I change limits for existing websites? A: Yes, modify the package and then run:
/usr/local/lsws/lsns/bin/lscgctl set-user <username> --cpu <percent> --mem <size> --tasks <count>
Q: Are limits enforced for email and FTP? A: The resource limits primarily apply to web processes (PHP). Email and FTP have separate process limits but share the same filesystem quotas (inodes).
Q: What happens when a limit is reached?
  • Memory: Process is killed (OOM)
  • CPU: Process is throttled
  • Processes: Fork/exec fails
  • Inodes: File creation fails
  • Connections: New connections are queued or rejected
Q: Can I disable resource limits after enabling them? A: Yes, uncheck “Enforce Disk Limits” in the package settings and recreate the website.
Support
For issues or questions:
Documentation: https://docs.cyberpanel.net
GitHub: https://github.com/usmannasir/cyberpanel/issues
Community Forum: https://community.cyberpanel.net
Table of Contents
