Development
There is no single best AI for coding without a threat model
Software engineer looking at a code diff and a trust boundary diagram
Choosing the best AI for coding is no longer just about comparing code quality, speed or context windows. Modern coding agents can read files, execute commands and connect to external systems, which means capability also creates an attack surface. The right choice therefore depends on the environment in which an agent operates. A solo developer, a software team and a security-sensitive enterprise can use similar AI technology while requiring very different controls around permissions, data and external tools.
In short: capability only matters inside a security context
The best coding agent is the one that combines sufficient capability with controls appropriate for its threat model. Security teams should consider what an agent can read, which commands it can execute, which external systems it can reach and how extensions are reviewed. A powerful agent with excessive access may ultimately be less suitable than a more controlled alternative.
Why coding agents need a different security model
Traditional autocomplete tools primarily suggested code for a developer to accept or reject. Agentic coding systems can go considerably further. Depending on their configuration, they may inspect a repository, modify files, execute shell commands or interact with services through external tool connections.
That creates two separate security questions. Teams still need to assess whether AI-generated code introduces vulnerabilities, but they also need to secure the agent performing the work. An agent that generates secure code can still create risk if its environment allows unnecessary access to credentials, files or connected services.
The main risks security teams should evaluate
A useful threat model starts by identifying how an agent or its extensions could be abused. Important risks include:
  1. Prompt injection: malicious instructions attempt to override expected agent behavior.
  2. Data exfiltration: sensitive project information is sent to an unauthorized endpoint.
  3. Dangerous shell commands: an agent is instructed to execute destructive or unnecessary commands.
  4. Secret harvesting: credentials in .env, AWS or SSH files are deliberately targeted.
  5. Obfuscated instructions: encoded content hides commands or malicious behavior.
  6. Excessive permissions: an extension receives network, filesystem or shell access that its task does not require.
These risks make context important when comparing coding agents. More autonomy is useful only when the controls around that autonomy are appropriate.
Three threat models, three definitions of “best”
The same coding agent can have a very different security profile depending on where it is deployed.
Scenario
Main priority
Main risk
What matters most
Solo developer
speed and flexibility
local file or credential exposure
visibility and approval controls
Development team
consistent workflows
unsafe extensions or inconsistent permissions
shared policies and audited skills
Enterprise
governance and containment
data leakage, credentials and external access
least privilege, logging and review
Solo developer: flexibility with visible controls
An individual developer may accept broader local access in exchange for speed. Terminal execution and extensive repository access can make an agent substantially more useful. The important boundary is visibility. Developers should understand which files the agent reads, which commands it executes and when external services or credentials become involved. Approval controls become especially valuable before consequential actions.
Development team: consistency matters more than freedom
A development team introduces another problem because different developers can install different skills, connect different services and configure permissions differently. Shared policies therefore become more important. Teams need rules for approved extensions, external connections, repository access and mandatory human review. The best coding agent in this environment is not merely productive. It also needs to fit a repeatable security model across the team.
Enterprise environment: containment becomes the priority
Enterprise agents may encounter private repositories, CI/CD infrastructure, databases and internal services. A malicious instruction or excessive permission can therefore have consequences beyond one developer’s machine.
Security teams need visibility into tool access, permissions, logging and third-party extensions. In this environment, a technically impressive agent can still be a poor choice if its attack surface cannot be adequately contained or audited.
Permissions matter more as agents gain tool access
Permissions should match the task rather than the maximum capabilities of the agent. A commit message writer has little reason to require network access, while a documentation generator generally should not need unrestricted shell execution. This follows the principle of least privilege: provide the access necessary to complete the task and nothing more. Security teams can also separate read, write and execution permissions so that gaining access to information does not automatically provide authority to modify it.
MCP connections expand the attack surface
MCP servers can give coding agents access to external capabilities such as databases, GitHub or internal tools. That makes them useful, but their risk profile differs from a simple instruction file. Security teams should inspect which tools a server exposes and whether those capabilities match its stated purpose.
A cautious evaluation can start with read-only tools. Teams can also verify server URLs, inspect source code when available and monitor network activity to understand which information is being transmitted. A GitHub integration unexpectedly exposing unrelated capabilities, for example, deserves further investigation before it becomes part of a development workflow.
Third-party skills deserve the same scrutiny as dependencies
Agent skills may consist of instructions rather than standalone executable software, but those instructions can still influence what an agent does with its available tools. A malicious skill could target secrets, introduce prompt injection or instruct an agent to run dangerous commands.
This makes provenance and review relevant. Agensi.io uses a three-layer process for submitted skills, consisting of an automated eight-point security scan, AI-assisted review and final human approval. Its automated checks include dangerous command patterns, hardcoded secrets, environment variable harvesting, network access, obfuscation and prompt injection signatures. Teams using skills from other sources can apply similar criteria during manual review.
Security scanning can become part of the coding workflow
Coding agents can also support the defensive side of development. Security-focused skills can guide agents through checks for common code vulnerabilities, outdated dependencies, exposed secrets and infrastructure misconfigurations. That can include looking for issues associated with the OWASP Top 10 or reviewing Docker, Kubernetes and cloud configuration for overly permissive settings.
These checks should complement rather than automatically replace existing security controls. Their advantage is that security review can move closer to the moment code is created instead of becoming exclusively a post-development activity.
A practical framework for choosing a coding agent
Before comparing models or product features, security and development teams can ask a smaller set of architectural questions:
  • What project data can the agent access?
  • Which shell commands can it execute?
  • Which external systems can it reach?
  • How are third-party skills and MCP servers reviewed?
  • Are permissions specific to the task?
  • Can important agent actions be inspected or logged?
  • What happens when the agent takes an incorrect action?
The answers provide a threat model against which capabilities can actually be evaluated.
The best AI for coding depends on what you are willing to expose
There is no universal winner because coding environments do not share the same assets, risks or tolerance for autonomy. A solo developer may prioritize flexibility, while a security-sensitive enterprise may consider granular permissions and auditability essential.
The more useful question is therefore not simply which coding agent produces the strongest output. Teams should first determine what data, systems and actions they are willing to expose to an agent. Only then can code quality, speed, integrations and autonomous capabilities be compared in the right security context.
