Have a Question?
< All Topics
Print
How to fix License Expired Redirect
Posted
Updated
Byadmin
If you have installed CyberPanel Enterprise and you are being redirected to License Expired Page. There are two major reasons for this:
- Your License has either expired or you have not correctly registered new key.
- License does not have CyberPanel Enterprise bundle. Licenses with CyberPanel bundle can be purchased from here. You can then change your license using License Manager.
Renew License
If your license is not expired you can skip this step, otherwise you need to open store and make sure you have renewed your license key.
Register New Key
Once you are sure that your key is not expired or you have already renewed it, open command line terminal and run
/usr/local/lsws/bin/lshttpd -r /usr/local/lsws/bin/lswsctrl restart
And then restart LSCPD
systemctl restart lscpd
For more details you can visit
Containerization
If you are being redirected from the containerization page (:8090/container/) it means you have CyberPanel installed (with OpenLiteSpeed). This feature is only available with CyberPanel Ent (with LiteSpeed Enterprise Web server)
Posted
Updated
Byadmin
