Version: 2.2.0 | Last Updated: December 28, 2025 | Status: Production Ready
Introduction
The CyberPanel OpenLiteSpeed Module brings Apache .htaccess compatibility to OpenLiteSpeed servers. Use familiar Apache directives without switching web servers.
Quick Start
- Module is pre-installed on CyberPanel servers
- Create .htaccess in your website’s public_html directory
- Add directives from this guide
- Test using curl or a browser
1. Header Directives
HTTP headers control browser behavior, caching, security, and more.
Supported Operations
| Operation | Purpose | Syntax |
| set | Set header (replaces existing) | Header set Name "Value" |
| unset | Remove header | Header unset Name |
| append | Append to existing header | Header append Name "Value" |
| merge | Add if not present | Header merge Name "Value" |
| add | Always add (allows duplicates) | Header add Name "Value" |
Security Headers Example
# Prevent clickjacking
Header set X-Frame-Options "SAMEORIGIN"
# Prevent MIME sniffing
Header set X-Content-Type-Options "nosniff"
# Enable XSS filter
Header set X-XSS-Protection "1; mode=block"
# Control referrer
Header set Referrer-Policy "strict-origin-when-cross-origin"
# Hide server info
Header unset Server
Header unset X-Powered-ByCache Control Headers
# Cache for 1 year (static assets)
Header set Cache-Control "max-age=31536000, public, immutable"
# No caching (dynamic content)
Header set Cache-Control "no-cache, no-store, must-revalidate"CORS Headers
# Allow cross-origin requests
Header set Access-Control-Allow-Origin "*"
Header set Access-Control-Allow-Methods "GET, POST, PUT, DELETE, OPTIONS"
Header set Access-Control-Allow-Headers "Content-Type, Authorization"2. Request Header Directives
Modify headers before they reach your PHP application.
| Operation | Syntax | Result |
| set | RequestHeader set Name "Value" | $_SERVER['HTTP_NAME'] |
| unset | RequestHeader unset Name | Header removed |
Behind Proxy Configuration
RequestHeader set X-Forwarded-Proto "https"
RequestHeader set X-Forwarded-SSL "on"
RequestHeader set X-Real-IP "%{REMOTE_ADDR}e"3. Environment Variables
| Directive | Purpose | Syntax |
| SetEnv | Set static variable | Set a static variable |
| SetEnvIf | Conditional set | SetEnvIf attribute regex VAR=value |
| BrowserMatch | Detect browser | BrowserMatch regex VAR=value |
Example Usage
# Application settings
SetEnv APPLICATION_ENV production
SetEnv DEBUG_MODE off
# Browser detection
SetEnvIfNoCase User-Agent "mobile|android|iphone" IS_MOBILE=1
BrowserMatch "Chrome" IS_CHROME=14. Access Control
Restrict access based on IP addresses.
| Directive | Syntax |
| Order | Order deny,allow or Order allow,deny |
| Allow | Allow from IP/CIDR |
| Deny | Deny from IP/CIDR |
Block All Except Specific IPs
Order deny,allow
Deny from all
Allow from 203.0.113.50
Allow from 192.168.1.0/24Allow All Except Specific IPs
Order allow,deny
Allow from all
Deny from 198.51.100.505. Redirect Directives
| Directive | Syntax | Use Case |
| Redirect | Redirect [code] /old /new | Simple redirects |
| RedirectMatch | RedirectMatch [code] regex target | Pattern-based |
Examples
# Simple redirect
Redirect 301 /old-page.html /new-page.html
# Pattern-based
RedirectMatch 301 ^/blog/(.*)$ /news/$16. Error Documents
ErrorDocument 404 /errors/404.html
ErrorDocument 500 /errors/500.html
ErrorDocument 403 "Access Denied"7. FilesMatch Directives
Apply directives to files matching a pattern.
Cache Static Assets
<FilesMatch "\.(jpg|jpeg|png|gif|webp|svg|ico)$">
</FilesMatch>
<FilesMatch "\.(css|js)$">
Header set Cache-Control "max-age=604800, public"
</FilesMatch>8. Expires Directives
ExpiresActive On
ExpiresByType image/jpeg A31557600
ExpiresByType text/css A2592000
ExpiresByType application/javascript A25920009. PHP Directives
| Directive | Syntax | Purpose |
| php_value | php_value name value | Numeric/string values |
| php_flag | php_flag name on/off | Boolean values |
WordPress Configuration
php_value memory_limit 256M
php_value max_execution_time 300
php_value upload_max_filesize 64M
php_value post_max_size 64M
php_flag display_errors off
php_flag log_errors onWooCommerce Configuration
php_value memory_limit 512M
php_value max_execution_time 600
php_value max_input_vars 1000010. Brute Force Protection
Built-in WordPress login protection against password-guessing attacks.
Quick Enable
BruteForceProtection OnDirectives Reference
| Directive | Values | Default | Description |
| BruteForceProtection | On/Off | Off | Enable protection |
| BruteForceAllowedAttempts | 1-1000 | 10 | Max attempts per window |
| BruteForceWindow | 60-86400 | 300 | Time window (seconds) |
| BruteForceAction | block/log/throttle | block | Action when exceeded |
| BruteForceXForwardedFor | On/Off | Off | Use real IP behind proxy |
| BruteForceWhitelist | IP list | (empty) | Bypass for trusted IPs |
Progressive Throttle (v2.2.0)
When using BruteForceAction throttle:
| Over-Limit Attempts | Delay |
| 1-2 | 2 seconds |
| 3-5 | 5 seconds |
| 6+ | 15 seconds |
Recommended Configuration
BruteForceAllowedAttempts 5
BruteForceWindow 300
BruteForceXForwardedFor OnWith IP Whitelist
BruteForceAllowedAttempts 3
BruteForceWindow 900
BruteForceAction block
BruteForceWhitelist 203.0.113.50, 192.168.1.0/24Complete WordPress .htaccess
# Security Headers
# Brute Force Protection
# Cache Static Assets
</FilesMatch>
Header set Cache-Control "max-age=2592000, public"
</FilesMatch>
# PHP Configuration
# WordPress Rewrite Rules
# BEGIN WordPress
<IfModule mod_rewrite.c>
RewriteEngine On
RewriteBase /
RewriteRule ^index\.php$ - [L]
RewriteRule . /index.php [L]
</IfModule>
# END WordPressTroubleshooting
Directives Not Working
# Check module installed
ls -la /usr/local/lsws/modules/cyberpanel_ols.so
# Restart OpenLiteSpeed
/usr/local/lsws/bin/lswsctrl restart
# Check logs
tail -50 /usr/local/lsws/logs/error.log.htaccess Permissions
chmod 644 /home/yourdomain.com/public_html/.htaccess
chown nobody:nogroup /home/yourdomain.com/public_html/.htaccessBrute Force Not Triggering
# Check shared memory
ls -la /dev/shm/ols/
# Create if missing
mkdir -p /dev/shm/ols && chmod 755 /dev/shm/ols
# Restart
/usr/local/lsws/bin/lswsctrl restartQuick Reference
Headers
Header unset NameAccess Control
Order deny,allow
Deny from all
Allow from 192.168.1.0/24Redirects
Redirect 301 /old /new
RedirectMatch 301 ^/blog/(.*)$ /news/$1PHP
php_flag display_errors offBrute Force
BruteForceAction throttleSupport
- GitHub: github.com/usmannasir/cyberpanel_ols
- Community: community.cyberpanel.net
Module Version: 2.2.0 | Last Updated: December 28, 2025
