Automation
Running Instagram Automation on 4G Mobile Proxies Without Bans
This article contains a paid placement.
It’s all about how you set it up. 4G mobile proxies give you the most trustworthy IP available, but having that IP isn’t enough to keep you out of trouble. What really matters is how you use it – your overall behaviour online and how you’ve set up your device.
Instagram doesn’t just look at the IP address when it decides to ban an account, it follows patterns of behaviour too. So even with a top-class mobile IP, you’re still likely to get flagged if your automation is sloppy. But with proper setup, you’ll have the best chance of running accounts without being banned.
Setting Up 4G Mobile Proxies for Your First Instagram Account
When using plan options to register your first Instagram account, you must start with a carrier IP. ProxyWing provides the endpoint and rotation settings required for that first setup. Before you open the account, make sure the proxy is connected.
Here’s the order:
  1. Buy a dedicated mobile proxy, one IP for this one account. Don’t share it.
  2. Set up device-level isolation for the account. A browser profile (like Dolphin Anty or GoLogin) spoofs a device fingerprint, which works, but it’s still a desktop browser pretending to be a phone on a mobile carrier IP, and that mismatch is exactly the kind of thing Instagram checks for. Multilogin covers both sides: it runs cloud phones, real Android devices in the cloud, so the fingerprint side matches the mobile IP because it genuinely is a mobile device, and it also offers isolated browser profiles for cases where a browser setup is what you actually need.
  3. Paste the proxy into the browser profile or cloud phone, in IP:PORT:USER:PASS format.
  4. Match the profile’s timezone and language to the proxy’s location.
  5. Test the connection and check the IP shows as mobile before you sign up.
Pinning One Carrier IP to One Account for Safe Warmup
There’s one thing that will keep your accounts from getting banned on Instagram: one account, one IP. Instagram links all profiles sharing the same IP, so if one gets banned, the rest can fall with it too.
From the beginning, keep the same mobile IP connected to that account. It should not be switched between accounts or logged in from another location. Because of that consistent connection, the account appears to be a real person using a single phone.
New accounts that immediately start mass actions are quickly flagged. For the first two weeks, it’s much better to go slowly.
Here is an example:
  • Days 1-3: Just browse. Watch some stories and like a few posts. No follows
  • Days 4–7: Follow 5–10 accounts and like 20–30 posts per day.
  • Days 8–14: Post once or twice, add light commenting, and gradually increase activity.
Pacing Rotation, Action Limits, and Device Fingerprints
Rotation
Use a sticky session and keep the IP the same for the whole time you’re logged in – this helps avoid mid-session IP changes, which can trigger Instagram’s anti-spam alerts thinking it’s account theft. It’s totally fine to get a fresh IP every time you log in though, as long as it’s still from the same country.
Action Limits
Don’t get too carried away even if you are on a ‘trusted’ IP – stick to human-like numbers. For a warmed up account, that’s 100-150 likes, 50-100 follows and 20-30 comments per day, spread out over the day. Throw in some random delays between actions – say 15-90 seconds – so your pace looks normal, not automated. Start low and build up.
Device Fingerprint
Your IP is hidden by the proxy, not your device. Each account requires its own fingerprint because Instagram also reads signals from your device and browser. If you’re using a browser profile, match the user-agent to a mobile device and give each one its own configuration, though there’s still an obvious mismatch between a desktop fingerprint and a mobile IP. Multilogin removes that mismatch by running the account on a real cloud phone instead of a browser, and it also offers isolated browser profiles for accounts or platforms where a browser setup makes more sense.
Spotting Flag Signals Before a Ban Lands
Action blocks
You try to follow or like something, and get a message that the action is blocked. That’s usually the first sign. One blocked action is a good reason to slow down – try stopping whatever you’re doing for a day or two, then ease back into it, but at a much lower pace.
Verification prompts
Your account suddenly asks you for a phone number or email confirmation – this is often what happens when Instagram thinks something’s not right. Complete it, then take a few days off from activity.
Reach drops
Your posts and stories start getting a fraction of the views they used to, with no obvious reason why. This could be a sign you’ve got a shadowban – the account still works, but Instagram decides not to show the stuff you’re posting. Best bet is to stop your automated activities and go back to manually posting for a week.
Login challenges
Instagram suddenly starts flagging your login as suspicious, or just logs you out from nowhere. Usually a sign that your IP address is the problem. Check to make sure your IP hasn’t changed and is still stable, and hasn’t suddenly been set to a different country. If you keep getting hit with these challenges, it’s probably time to have another good look at your setup before you carry on.
Scaling to a Multi-Account Instagram Workflow
Keep the 1:1 ratio. Every account gets its own mobile proxy and its own browser profile. Don’t share IPs to save money. One shared IP can chain-ban a whole batch of accounts.
Spread out your accounts. Don’t warm up 20 accounts on the same schedule with the same actions. Instagram spots repeated patterns, so offset your start dates and vary the daily numbers.
Organize the setup. Each account, its proxy, its login window, and its warmup stage should all be listed on a sheet. This prevents you from using the incorrect IP to log into an account.
Grow in batches. Add accounts gradually rather than all at once. Run a batch, keep an eye out for flags, and once it holds, add more.
Instagram Automation Tasks Rated by Ban Risk on 4G
Automation Task
Ban Risk on 4G
Recommended IP Ratio
Rotation Advice
Browsing & viewing stories
Low
1 IP: 1 account
Sticky session while active
Liking posts
Low
1 IP: 1 account
Sticky session, spread through the day
Following / unfollowing
Medium
1 IP: 1 account
Sticky session, stay under daily caps
Commenting
Medium
1 IP: 1 account
Sticky session, random delays
Posting content
Medium
1 IP: 1 account
Sticky session, hold same IP per upload
Story / Reel automation
Medium-High
1 IP: 1 account
Sticky session, keep numbers human
DM automation
High
1 IP: 1 account
Sticky session, only on aged accounts
Mass actions (bulk follow/DM)
Very High
1 IP: 1 account
Avoid; fastest path to a ban
4G Proxy and Instagram Automation Setup Questions
Are 4G mobile proxies safe for Instagram automation?
It is the safest type of proxy, but it isn’t guaranteed. Mobile IPs have a high level of trust as the real user shares them with the carrier network. The proxy takes care of the IP side. Everything else is up to you and how you use your device.
How many Instagram accounts per 4G mobile proxy?
One. Always keep it 1:1. When you share a mobile IP with another account, they’re all tied together, and when one account is banned, so are the others. Getting a little bit of savings on proxies is not worth losing a bunch of accounts.
Why does Instagram ban accounts on datacenter proxies?
Hosting companies provide Datacenter IPs and Instagram is aware of the Datacenter IP ranges. They have no real-user history and they look automated. Because mobile IPs are real IP’s from real carriers, they hold up when datacenter fails.
How often should a 4G proxy rotate for Instagram?
Keep the IP steady while you’re logged in, using a sticky session. Rotate between sessions, not during one, since a mid-session IP change looks like account theft. A fresh IP per login window is fine, as long as it stays in the same country.
