Rewrite Rules
CyberPanel is based on OpenLitespeed and LiteSpeed Enterprise as well, and it fully supports mod_rewrite syntax. If you want to add rewrite rules to your site, you can do so easily.
To set rewrite rules first go to Main > Websites > List Websites >Manage
Launch website management dashboard for each website looks like this:
Once you are in the website dashboard click REWRITE RULES a box will open which will contain your current rewrite rules, if there are none it will be empty.
You can add any rewrite rules in this and make sure that if you are using OpenLiteSpeed then restart the web server after adding any rewrite rules.
