Upgrade CyberPanel
Have a Question?
< All Topics
Print
Upgrade CyberPanel
Step 1: Login into your server using any SSH client (Like bitwise SSH client) or terminal via the provider.
Step 2: Enter your IP address and login credentials Username, password, and then click on login
Step 3: When you log in to the Bitwise SSH client open the terminal and run the command.
The following command can be used to upgrade to the latest version.
If using a sudo user rather than root, try this:
sudo su - -c "sh <(curl https://raw.githubusercontent.com/usmannasir/cyberpanel/stable/preUpgrade.sh || wget -O - https://raw.githubusercontent.com/usmannasir/cyberpanel/stable/preUpgrade.sh)"
How to Upgrade CyberPanel- Detailed Tutorial
How to Upgrade CyberPanel to a Specific Version
wget https://raw.githubusercontent.com/usmannasir/cyberpanel/<branch name>/cyberpanel_upgrade.sh
chmod +x cyberpanel_upgrade.sh
./cyberpanel_upgrade.sh
Step 1: Remove old script:
First, you have to remove the old script file to get a new and upgrade. Use the command given below to do this.
rm -rf cyberpanel_upgrade.sh
 Step 2: Download specific branch script:
Now in the next step, you have to download the script for the new branch you want to install using the command stated below.
wget https://raw.githubusercontent.com/usmannasir/cyberpanel/v<branch>/cyberpanel_upgrade.sh
remove <branch> to your required branch name
Step 3: Give execute Permissions :
using the command stated below gives the upgrade command execution permissions.
do all this in / or root directory and you must log in as root.
Step 4: Run upgrade script:
Now in the last step just run this command and wait when the system asks for the version give the branch version like “2.0.1-dev”
Updates between official versions
Even when there hasn’t been a new version of CyberPanel officially released, there are always minor updates happening behind the scenes. In order to take advantage of these, you can upgrade CyberPanel at any time.
Table of Contents
