How to Secure Your Mac for Remote Work: A Comprehensive Privacy Guide
By Nektony CTO Yuriy Varbanets — a software development company specializing in macOS optimization, cleanup, and security utilities. With over a decade of experience in the Apple ecosystem, Yuriy is passionate about helping users maximize their computer potential through fast, safe, and efficient software.
Remote work isn’t a trend anymore. For a lot of us, it’s just… work. Whether you’re answering Slack messages from a kitchen table or pushing code from a coworking space, your Mac has become your office. I’m Yuriy Varbanets, CTO of Nektony, and when your office is everywhere, your privacy must travel with you. In this guide, I’ll outline the essential steps I recommend to ensure your data stays private, no matter where you choose to work.
Cybersecurity Threats if You Work Remotely
Working outside a traditional office network changes the risk equation. There’s no corporate firewall quietly filtering traffic for you. No IT team is watching network logs. It’s just your Mac, your Wi-Fi, and tools you’ve installed. Without even noticing, today’s risks are high out there:
  • Hyper-personalized phishing messages — Emails and Slack messages crafted with scraped LinkedIn data or breached info, written so naturally they don’t raise red flags at first glance.
  • Shadow IT and random downloads — Quick installs of niche tools, GitHub utilities, or “free” converters that request broad permissions and quietly initiate background connections.
  • Session hijacking on unknown Wi-Fi — Attackers intercept unsecured connections and reuse authentication tokens to access your cloud accounts.
  • Unauthorized inbound connection attempts — Remote scans, brute-force login attempts, or exploit probes targeting open services on your Mac.
  • Too many always-on SaaS connections — Multiple cloud apps running in the background, syncing data, maintaining active sessions, and expanding your exposure surface.
  • Unrestricted app-level internet access — Applications freely connecting online without clear necessity or user awareness.
Best Practices to Secure Your Mac for Free
Remote security isn’t about installing ten different tools and hoping for the best. It’s about layered protection. Here’s what that looks like in practice.
1. Use a Firewall to Control Which Apps Connect to the Internet
When you work remotely, dozens of apps connect to the internet silently — sync tools, menu bar utilities, cloud agents, and some new tools you installed to test or use. Without visibility, you don’t know what’s active, what’s idle, or what shouldn’t be connecting at all.
A free dedicated firewall like FireWally fixes this by showing you exactly which applications are using your network — in real time. With it, you can:
  • See a live list of apps currently sending or receiving data
  • Track usage over time with Real-time, Hour, and Today views
  • View how much data each app has transferred
  • Block or unblock any app’s internet access instantly with a simple toggle
FireWally also goes a step further by using Apple Intelligence to explain why an app is connecting to the internet. Instead of guessing whether a connection is not bad, you get plain-language insights that help you make informed decisions.
This kind of visibility is especially useful for remote workers who regularly install new tools, use multiple SaaS platforms, or work across different networks.
Note: You can always enable a Mac firewall in System Settings → Network → Firewall. It’s better than nothing, but it’s limited to incoming connections and comes with no extras.
2. Avoid Unknown Wi-Fi without a VPN
A VPN encrypts all data between your Mac and the internet, making it much harder for anyone on the same network to eavesdrop. When using remote networks:
  • Always enable a trusted VPN before logging in to email, cloud apps, or internal tools.
  • Avoid accessing sensitive services (banking, admin dashboards) without encryption.
  • Treat every new Wi-Fi as potentially unsafe until verified, even if it appears secure.
  • Prefer known networks with strong passwords and WPA3 encryption if possible.
3. Use Encrypted DNS
Even with a VPN, your DNS queries can leak sensitive data. Encrypted DNS ensures that your web requests are private and harder for attackers or ISPs to intercept. Mac allows you to do it:
  • Go to System Settings → Network → Wi-Fi → Details → DNS
  • Add a trusted encrypted DNS provider (like Cloudflare 1.1.1.1, Google 8.8.8.8 with DNS-over-HTTPS, or DNS-over-TLS (DoT))
  • Enable encryption if the option is available
4. Enable Two-Factor Authentication (2FA)
Strong passwords alone aren’t enough. Any tool you use for work — email, Slack, cloud storage, banking, project management — should be protected with two-factor authentication.
Once active, logging in requires both your password and a unique, time-sensitive code from a trusted device or authenticator. This way, even if a credential leaks, your accounts stay locked.
Start with your Apple ID: Go to System Settings → Apple ID → Sign-In & Security and make sure Two-Factor Authentication is turned on.
Then enable 2FA for:
  • Email providers
  • Slack and collaboration tools
  • Cloud storage (Google Drive, Dropbox, etc.)
  • GitHub and developer platforms
  • Banking and financial apps
5. Set Lock Screen to “Immediately”
By default, some Macs wait a few minutes before requiring a password after the screen goes dark. Setting this to “Immediately” ensures your data is locked the moment you close the lid or the screensaver starts.
  • Go to System Settings → Lock Screen and set the option for “Require password after screen saver begins or display is turned off” to Immediately.
6. Enhance Safari Privacy
Safari has built-in features to stop websites from tracking you across the internet.
  • Open Safari → Settings → Privacy. Check the boxes for Prevent cross-site tracking and Hide IP address from trackers.
7. Review Privacy Permissions (Location, Camera, Mic)
Regularly auditing which apps have access to your hardware and location is vital for privacy.
  • In System Settings → Privacy & Security, check the following:
    • Location Services: Ensure Find My is On so you can track your Mac if lost.
    • Camera & Microphone: Disable access for any apps that don’t strictly need it.
8. Enable FileVault Encryption
FileVault encrypts your entire hard drive so that if your Mac is stolen, your data cannot be accessed without your login password or recovery key.
  • Go to System Settings → Privacy & Security → FileVault and turn it On.
  • Enable FileVault for disk encryption.
  • Keep macOS and apps updated.
9. Lock Apple ID Access
To prevent someone from signing you out of your Mac (which would disable “Find My”), you can restrict account changes.
  • Go to System Settings → Screen Time → Content & Privacy. Turn it On, go to Preference Restrictions, and turn Off the toggle for Allow Account Changes.
Final Thoughts
Working remotely means your Mac needs to be protected since it is now the gateway to sensitive work data, personal information, and the SaaS tools that keep your projects moving.
Implementing layered protections makes all the difference: a firewall to manage app traffic, a VPN to secure connections on unknown networks, 2FA to lock down accounts, and built-in macOS features like FileVault and privacy controls to keep your data safe.
With these steps in place, you can work confidently knowing your Mac is secure, no matter where your office happens to be. And remember: security isn’t a one-time setup, it’s an ongoing habit that keeps you safe as threats evolve.
