Top things to look for in a dark web monitoring
The number of threats on the internet is constantly increasing. As a business, it is imperative that you safeguard your assets and data from threats, especially those arising from the dark web. A crucial component of doing this is dark web monitoring. Considering how complex it can get, with new changes, doing this may come across as difficult.
With the right guidance, you should be able to get useful insights and maximize on security. And those that are unable to perform this on their own can opt for reliable dark web monitoring services according to ImmuniWeb. The goal should be to find a service that will meet your needs and lead to improved security. Let’s look into why dark web monitoring is a must and how to find the best provider.
Why is it important?
The dark web provides a place for criminals to steal valuable data. They are constantly searching for vulnerabilities from unsuspecting victims. The type of fraudulent activities range from leaked data to hacking. The number of cyber attacks is growing at an alarming rate.
That’s where reliable dark web monitoring solutions come in. It is simply a process that allows you to monitor the dark web, something that most search engines cannot access. The browsers used are specialized and are designed to search for specific data. Monitoring can be for:
  • Keywords or phrases
  • Company names
  • User names
  • Passwords
  • Email addresses
  • Login credentials
  • Financial data
  • Personal information
When you search for these, it exposes potential vulnerabilities that cybercriminals may also view. This is a good initiative that allows companies to resolve vulnerabilities in an effort to beef up security measures. As a result, the industry was worth 520.3 million US dollars in 2023, a value that will increase in the next 10 years. So why should you consider this? There are a number of reasons.
Threat detection
Detecting threats early on gives you the opportunity to contain the extent of a breach. So before additional information is compromised, you can maximize security measures, thereby keeping your company data safe. This also provides a proactive way to handle threats. Instead of acting when a threat is detected, you can stay ahead of hackers.
Brand protection
Many hackers may look for information that may be damaging to a company’s reputation. By monitoring the dark web, you can identify which damaging information criminals may access. This puts you in a good position to remove anything that may compromise the image of your business.
Compliance
Compliance regulations require that companies keep customer information secure. If you search on the dark web, it’s easy to identify which sensitive data is at risk. This gives you room to improve security and avoid legal issues and fines. This is especially important for healthcare industry data breaches. This can lead to mistrust and hefty fines.
Things to look for
You can find several solutions that offer monitoring of dthe ark web in the niche. These work by constantly monitoring the web for potentially compromising info. This is specific to a company and their services. It may include any sensitive information that could be utilized for fraudulent purposes.
A tool searches for data related to a company. When this data is on the dark web, the next step is to understand whether it is legit and poses a threat to your company. Once it has been deemed to be harmful, you will get a notification showing your data is at risk. When looking for a tool, there are certain features that are a must. These will ensure that you are successful in amplifying your security.
Real time alerts
A good service should provide real time alerts whenever threats are detected. This gives you ample time to eliminate the risk. The alerts can be in form of:
  • SMS
  • Mobile notifications
  • Emails
Having multiple channels is better as some users may use one more than others. Alerts should be customized to suit individual company needs.
Custom breach reports
A good tool should provide a convenient way of being data. Therefore, having a custom dashboard is important. It means you can choose the design that suits your company best, therefore making it easy to view data. Reports should be detailed to provide a better idea of the extent of a breach. Key insights include:
  • Compromised data
  • Location
  • Source of threat
This makes it easier for your team to initiate the appropriate action. It also provides areas of focus that your security team should improve.
Continuous monitoring
The process never stops. Having a continuous monitoring system allows you to be alert all the time. New threats are easily picked up and eliminated through this process. This helps you to stay ahead of any hackers.
Integration
Make sure you pick a tool that can be easily integrated with your current security tech stack. This helps you create an efficient and seamless system. You can leverage both existing and new tools to create a great security strategy for your business. Flexible solutions can help you get the specific service that your business needs.
Support
Because monitoring is continuous, you need to have access to customer support. This should be readily available so that the tool can continue monitoring the dark web. Also ensure that this is available 24/7. Aside from this, you may also need staff training at the beginning. This can help you maximize on the services provided.
Final thoughts
Hackers are getting smarter and can access important data through the dark web. The best option to safeguard your assets is through dark web monitoring. This allows you to detect threats on time. Because there are many options when selecting providers, knowing what to look for can be helpful.
Make sure the tool comes from a reputable company, can be customized and offers real-time alerts. Also ensure that it can be easily integrated with other existing tools. Having access to reliable dark web monitoring services will ensure that all your digital assets are kept safe. Access to customer support is crucial as it helps you continue monitoring for threats without fail.
